Building 2pi Towers - COMPLETE! [message #38688] |
Thu, 17 October 2002 05:59 |
Fresno
Messages: 41 Registered: May 2009
Baron |
Whew! They are done except for some minor touch-ups. I hooked them up and I could tell they were out of phase, fortunately it was not wired wrong internally, so I just corrected the left speaker and it was fixed. A snag I ran into was that the wiring that goes from the binding posts to the driver was not long enough for where I put the binding posts. I had to extend the wires by 23" to make them reach the drivers. That's what really scared me about them being out of phase. I didn't want to have to take them apart to find out I wired them wrong. I guess the wiring included in the kit assumes that the binding posts will be about two feet off the ground. I wanted them at the bottom, it looks better to me. So how do they sound? They sound very nice, I was expecting more volume since they are more sensitive than the speakers they are replacing but there is an improvement there. I am trying to see if I can get away with having no pre-amp, just a volume control on a tube amp. I'll have to put the pre-amp back into the mix until I build a more powerful amp. There is far more detail in the sound, I played quite a few favorite tracks and I was picking up a lot more detail in the music that I never heard. The 'reality' of the sound is impressive, the instruments sound much richer and, well, real. The bass was sorely lacking, not sure if this will come with break-in time or if it has something to with the my amp, it is a 6BQ5/6CG7 PP amp. The imaging was not as 'crisp' as I was hoping, this may be due to finding the right speaker placement through experimentation. Overall I am happy with the results, break-in/speaker placement/amp changes should cause even greater happiness. So what is the final tally for labor and parts? It cost a total of $210 for the kits, shipping and materials. It took a total of 26 hours to build them. I spent $130 on tools but that is 'off budget'. Kit+shippng 120.00 MDF........ 33.00 Glue....... 8.00 Primer..... 7.00 Insulation. 9.00 Screws..... 5.00 Paint...... 17.00 Sandpaper.. 8.00 Braces..... 3.50 TOTAL...... 210.50
Labor - Speaker Box 1 - 16.5 hours Labor - Speaker Box 2 - 9.5 hours Tools: Saber Saw.... 40.00 Circular Saw. 50.00 Carbon Blade. 40.00 TOOLS TOTAL.. 130.00
Break-in [message #38689 is a reply to message #38688] |
Thu, 17 October 2002 08:42 |
JLapaire
Messages: 156 Registered: May 2009
Master |
Congratulations on getting them finished! I built a slightly larger version of the Studio, not as large as the Tower, but noticed an improvement in bass after they ran in for a couple of days. I usually hook new speakers to a car stereo out in the greenhouse and let them shout for a couple of days before giving them a critical listen. Since I sold my mains, the "Studio" 2s got hooked right up in the house and the first impression was very bass-light. They got much better after a week or so of intermittent use. If you can pump some power into them they'll wake up faster.John
Re: Building 2pi Towers - COMPLETE! [message #38691 is a reply to message #38688] |
Thu, 17 October 2002 11:45 |
Messages: 18695 Registered: January 2001
Glad you finally got your speakers together! Lots of work on those! Sorry about the wiring - You ordered two π kits rather than tower two π's, and the cable assemblies included in the standard bookshelf version kits are shorter. There is no difference in the components in the two kits, but there is a little difference in the wiring harness and the ports. The bookshelf version has shorter wires so that there isn't a bunch of wire in the cabinet just looped around inside. The towers need 5 foot length, so the cable assembly is longer. I also include a strain relief in the tower kits since longer wires will be supported. But the tower kits do not include port material since none is needed, and the bookshelf version includes a duct. About the bass, double check everything - The wiring, phasing, connection to the amp, etc. I've never heard anyone comment that the towers lacked bass; The comments are always quite the opposite. So I think there may be something wrong, and more than could be explained by break-in. I suspect phase might be the culprit, so reverse the wires on one speaker and see if the bass is increased. If that's the problem, you'll notice a significant difference after reversing the wires.
Re: Break-in [message #38692 is a reply to message #38689] |
Thu, 17 October 2002 11:49 |
Fresno
Baron |
>>Congratulations on getting them finished! Thanks. My wife is happy she has the porch back. >>I usually hook new speakers to a car stereo out in the greenhouse >>and let them shout for a couple of days before giving them a >>critical listen. She might go for the greenhouse but that will need to wait till spring. ;) >>If you can pump some power into them they'll wake up faster. I can hook them up to the sand amp for a bit and crank out some tunes!
Re: Building 2pi Towers - COMPLETE! [message #38694 is a reply to message #38691] |
Thu, 17 October 2002 12:20 |
Fresno
Baron |
Yup, I did originally order the regulars, after I rec'd them I decided to go with towers. I tell ya Wayne, wire doesn't stretch very much! I improvised converting them to towers, If I screwed up the phasing anywhere it would be in there. When I first hooked them up I could hear the tweeters were out of phase (unfocussed image), so I went around back and fixed it. I'll have to see if when I switch them back the bass gets boosted, if so, then I'll need to open hopefully only one them up and check/fix. Thanks for the input
Re: Building 2pi Towers - COMPLETE! [message #38700 is a reply to message #38691] |
Thu, 17 October 2002 17:24 |
Fresno
Baron |
Wayne, I reversed the cables on one of the speakers and the bass dropped to nothing and the mids and highs went out of focus. It is not the phase. We'll have to see how it sounds when the preamp is hooked back up and the speakers are broken in.
Re: Building 2pi Towers - COMPLETE! [message #38707 is a reply to message #38703] |
Fri, 18 October 2002 06:48 |
Fresno
Baron |
>>Do you have a raised hardwood floor, on a second floor or are you >>on a concrete slab?I am in a finished basement with a w/w rug on the concrete. 26' x 19'. The front and back walls are panelling an ich or two away from concrete. The side walls are panelling with rooms on the other side. >>Do you have anything else you can compare with - A different amp, >>for example? I hooked them up to my sand amp, SONY STR-DE935, the bass is a bit better. Being able to crank them up louder, I noticed that there was very 'excursion' of the woofer until very high loadness. By excursion I am referring to being able to see the cone move enough to move in and out at the ripples on the outer edge of the cones. >>Same question on the speakers, are they bass-shy on the same amp, >>different amps and/or in different rooms? Not able to test this out yet, won't be able to test different rooms. Would you like to swing by this weekend and check things out? ;)
