Home » Sponsored » Pi Speakers » Pro Series 7 Pi-18 questions
Pro Series 7 Pi-18 questions [message #38559] Thu, 03 October 2002 18:36 Go to next message
GJP60 is currently offline  GJP60
A cabinetmaker friend just delivered the beautifully finished 3/4 cherrywood cabinets (It was worth the three month wait). They're also beautifully huge. So now it's time to get off my duff. I purchased all the drivers used, on the net, and none of them came with any hardware. Could someone please tell me the type of bolt used in mounting the JBL2445 driver to the 2380A horn? What type of hardware would you recommend for mounting the 2380A horn to the cabinet? What type of hardware would you recommend for mounting the JBL2241 to the cabinet? Gaskets?
Thanks,
Gerry Provenzale
Pro Series 7 Pi-18 answers [message #38560 is a reply to message #38559] Thu, 03 October 2002 23:54 Go to previous messageGo to next message
You'll need 1/4"-20 bolts to mount the horn on the driver. As for mounting to the cabinet, I suggest machine screws and T-nuts:
Post some pics when you can, those sound gorgeous!
Re: Pro Series 7 Pi-18 answers [message #38561 is a reply to message #38560] Fri, 04 October 2002 07:23 Go to previous message
Hi Wayne,
Thanks again for your help. I figured T-nuts was the way to go. And I will gladly post some pictures, but not until I put the logo's on. :>)
Gerry Provenzale
Previous Topic: Wayne: Please send Theater 4 Pi Plans - Thanks!!!
Next Topic: One More Pro Series 7 Pi-18 Question
Current Time: Wed Oct 21 05:02:14 CDT 2026
