| Help me! What to do about 2Pi port [message #38343] |
Wed, 18 September 2002 13:56  |
BillEpstein
Messages: 886 Registered: May 2009
Illuminati (2nd Degree) |
As you saw from the pix, the holes are drilled for the ports at 2"dia. The paper towel roll is 2 1/8" O.D. Has anybody dealt with this? Ideas? Should I just get a pair of plastic port thingys from P.E.?
| Did we forget to include duct material in your kits? [message #38344 is a reply to message #38343] |
Wed, 18 September 2002 14:07   |
The port is spec'ed at 2.0" O.D. with 0.030" wall thickness for an inside diameter of 1.94".Did we send you the port material? Because if we did, you'll want to drill to fit. Would it mess up the veneer to do that? If we forgot to send the port, let me know and we'll send it right away.
