Home » Sponsored » Pi Speakers » L Pad & Trimmer
L Pad & Trimmer [message #38295] Fri, 13 September 2002 15:23 Go to next message
Zeno is currently offline  Zeno
can anyone please tell me what is the different between a trimming resistor and a L pad?
Re: L Pad & Trimmer [message #38298 is a reply to message #38295] Fri, 13 September 2002 17:11 Go to previous message
Most engineers and technicians call a very small potentiometer a "trimming resistor." They are usually 1/4 watt or 1/8 watt units, come in a variety of resitance ranges and they come in 20 turn versions as well, for very fine adjustments. L-Pads are usually rather large, like 10 watt or larger, and they are usually for low impedance circuits, having a low resistance range. They use series/parallel values that are designed to match the total load impedance to what it would have been without the pad. Other than that, they're basically the same thing - a resistor voltage divider.
Previous Topic: 8 ohm & 4 ohm
Next Topic: Interpreting system impedance curve
Current Time: Fri Nov 06 06:57:03 CST 2026
