Home » Sponsored » Pi Speakers » horn lenses
horn lenses [message #37989] Thu, 22 August 2002 13:49 Go to next message
jpowers is currently offline  jpowers
Is there another horn lens other than the JBL 2382, which I just found out costs $250 ea., that will work with the JBL 2446H. Seems like a huge amount of money for a lens
Re: horn lenses [message #38005 is a reply to message #37989] Thu, 22 August 2002 17:55 Go to previous message
P-Audio makes inexpensive copies of the most common JBL horns. I got
my 2370A clones locally for 70$ each. Nice horn for a fraction of the
cost. only a pro could tell the difference, and it isn't cheaply made
at all. Check Speaker City if you don't have then available locally.
Thomas
Previous Topic: Who is close to Omaha, Nebraska
Next Topic: Zero Box Enclosure-How Too?
Current Time: Fri Nov 06 04:40:13 CST 2026
