Home » Sponsored » Pi Speakers » 2 Pi Tower Plans
2 Pi Tower Plans [message #37960] Thu, 22 August 2002 03:40 Go to next message
JohnB is currently offline  JohnB
Hello:
Wayne - could please I get the 2 Pi tower plans. I just received the bookshelf 2 Pi plans, fortunately I haven't bought lumber or begun the project yet.
BTW thanks for the reply regarding the piezos (post below).
Thanks,
John B.
You've got mail! [message #37961 is a reply to message #37960] Thu, 22 August 2002 03:44 Go to previous messageGo to next message
Re: 2 Pi Tower Plans [message #37969 is a reply to message #37960] Thu, 22 August 2002 07:07 Go to previous messageGo to next message
Edwin is currently offline  Edwin
Hi Wayne,
By using a 5/8" cabinet and a port length of 5/8" it is my understanding that you don't need to put anything in the port hole anymore. Will the port diameter and port lenght change if I use a 3/4" MDF with the 2Pi Towers?
Thanks,
Edwin
Additional 3/4" MDF question [message #37975 is a reply to message #37969] Thu, 22 August 2002 10:15 Go to previous messageGo to next message
would the design still be ok if you made it out of 3/4 in. MDF with 48" H.,16" width, and 12" depth? Do the multiples of 4" create a standing wave problem? In rough cubic feet (not allowing for the thicker wood) it's 66.44 as designed and 64.0 as above. Purpose of change would be to get 4 sides that could be built easily with the pre-made 3/4" MDF shelves (which come in 12 and 16" sizes). If it might sound worse, no big deal to do the woodwork...
Additional 3/4" MDF answer [message #37992 is a reply to message #37975] Thu, 22 August 2002 14:23 Go to previous messageGo to next message
When making the cabinet with 3/4" wood, cut the port hole 4 5/8" diameter. I can't say what you'll get if you modify overall cabinet dimensions, but I expect it will be OK if you don't vary too much. Keep volume the same and leave the distance between port and cabinet floor the same. Also maintain the distance relationships between the woofer, the tweeter and the top of the cabinet.
Re: Corrected 3/4" MDF calculations [message #37998 is a reply to message #37992] Thu, 22 August 2002 15:02 Go to previous messageGo to next message
Wayne-
To use the pre-cut shelves, I realized a mistake I made above. If you used the 12" shelves for sides inside the 16" front and back, the ext. depth would be 13 1/2", comparing apples to apples. This extra 1/2" almost makes up the decreased volume caused by using 3/4" instead of 1/2". I calculated the internal volume of your plan, using 5/8" as 7,756 cu. in. (53.86 cu.ft.). If you used the 3/4"mdf, with the 13 1/2" depth, the internal volume would be 7,743 cu.in. (53.77cu.ft.)-practically the same.
Internal dimensions would be 14 1/2 x 44 1/2 x 12, so there shouldn't be a standing wave problem, huh?
Re: Additional 3/4" MDF answer [message #38240 is a reply to message #37992] Mon, 09 September 2002 12:40 Go to previous message
JLM is currently offline  JLM
Years ago I built a pair of 8 inch transmission line enclosures and somehow made one a half inch wider than the other (discovered at the veneering stage). No one noticed or could tell the difference.
Previous Topic: tall Studio 2 ???
Next Topic: I'm not gonna be able to fit into my helmet
Current Time: Sat May 11 06:47:19 CDT 2024
