Home » Sponsored » Pi Speakers » Wayne: About those Cornerhorns?
Wayne: About those Cornerhorns? [message #37895] Tue, 20 August 2002 06:46 Go to next message
Edwin is currently offline  Edwin
Hi Wayne,
I was rereading your old post about "Making speakers disappear" and this made me a little curious once again. Also, you said before that if you have corners, build corner speakers. In a few months I will be building a small, dedicated, listening room which is 12 ft by 15 ft with a 10 feet slightly domed ceiling and I am wondering if I can use the Theater 7Pi for this project. I plan to position it on the short wall. Will this be okay? Will treating the roon acoustically be easier with this set-up if ever? This will be driven by the Foreplay/Paramour combo.
Best Regards,
About those Cornerhorns [message #37900 is a reply to message #37895] Tue, 20 August 2002 14:20 Go to previous messageGo to next message
Perfect! They usually work best on the short wall, with the premium listening area just behind where the forward axis cross.
Also notice the posts in the thread called "Cornerhorns!"
π cornerhorns work great, and they're incredibly simple.
Re: About those Cornerhorns [message #37906 is a reply to message #37900] Tue, 20 August 2002 17:28 Go to previous messageGo to next message
Hi Wayne,
Thanks! Can I request for the plans of the Theater 7 if I may :-)?
Best Regards,
Edwin
You've got mail! [message #37912 is a reply to message #37906] Tue, 20 August 2002 22:41 Go to previous messageGo to next message
Thanks, Wayne (nt) [message #37918 is a reply to message #37912] Wed, 21 August 2002 02:09 Go to previous message
Previous Topic: Question about power compression
Next Topic: Earth to replay, HELP!!
Current Time: Fri Oct 16 06:32:33 CDT 2026
