Home » Sponsored » Pi Speakers » converting port size
converting port size [message #37824] Fri, 16 August 2002 04:45 Go to next message
hi wayne, i'd like to convert the premium stage 4 pi's port from the rectangular version to a 4" round. can this be done and if so what is the depth?
cheers,
george
Re: converting port size [message #37831 is a reply to message #37824] Fri, 16 August 2002 10:31 Go to previous messageGo to next message
That's getting pretty small for earthshakers like the Premiums are. But you can expect the same tuning frequency if you'll make a 4" diameter port that's 3.5" long.
I recommend that you consider keeping the larger rectangular port if you can.
Re: converting port size [message #37833 is a reply to message #37831] Fri, 16 August 2002 10:57 Go to previous messageGo to next message
what about using a larger round port, say 6"?
cheers,
george
Re: converting port size [message #37839 is a reply to message #37833] Fri, 16 August 2002 13:29 Go to previous message
A 6" diameter port would be perfect - Make it 10" long. But the trouble is that you can't fit this port in the cabinet; It's a tight squeeze.
Then again, if the compression horn is mounted externally, you might not have any trouble fitting the 6" round port. And I know how you like to put those cool wood horns on top of the cabinets!
Previous Topic: theater four pi's finished (longish)
Next Topic: ZMAX How ?
Current Time: Tue May 07 11:21:51 CDT 2024
