Home » Sponsored » Pi Speakers » Anyone have a spec sheet for MD2001
Anyone have a spec sheet for MD2001 [message #37798] Wed, 14 August 2002 06:42 Go to next message
demanddeepbass is currently offline  demanddeepbass
Hi guys I've been offered the choice of a pair of Eminence MD2001s or a pair of PSD2002s but the specs for the 2001 have been taken off the Eminence website now, does anyone have a copy? Also any comments from people who have compared both would be much appreciated. I want to X-over at about 1.2K, poss slightly lower (might make the 2002 a bad option) and I don't want to add another driver above this one (might make the 2001 a bad option - from memory it was only rated to 15K?????). Which one:
A. sounds nicer?
B. could be more easily EQed/have it's X-over tweaked, to cover the range I want it to?
Cheers,
Olly
P.S. I'm using a Behringer CX3400 as X-over which has 24dB/octave filters. Is the suggested working range for the 2002 using 12dB/octave and if it is would this mean I could go a bit lower with 24dB filters?
Re: Anyone have a spec sheet for MD2001 [message #37800 is a reply to message #37798] Wed, 14 August 2002 11:29 Go to previous message
You've got mail!
I've sent LMS measurements of the Eminence MD2001 and the 2039 Type I and Type II drivers.
Previous Topic: RE: New Models
Next Topic: Crossover network
Current Time: Fri Nov 06 07:14:03 CST 2026
