Home » Sponsored » Pi Speakers » JBL 2426 Replacement Diaphragms
JBL 2426 Replacement Diaphragms [message #37707] Thu, 08 August 2002 10:54 Go to next message
Rog is currently offline  Rog
Hi Wayne and gang,
I have lots of JBL 2426 comp drivers and don"t want to spend the silly money on new JBL replacement diaphragms. So are there any good alternatives. I have been told that there are some good Asian copies, but to stay away from the ones from China.
Any ideas. They will be used on baby bums with JBL 2206 drivers and fed with zillions of watts for idiots to play through live.
Thanks in advance.
Re: JBL 2426 Replacement Diaphragms [message #37711 is a reply to message #37707] Thu, 08 August 2002 12:44 Go to previous messageGo to next message
I've heard that Radian sells a replacement diaphragm for the 2426, but I have no experience with them. I prefer to have my JBL components refurbished with genuine JBL parts.
Re: JBL 2426 Replacement Diaphragms [message #37716 is a reply to message #37711] Thu, 08 August 2002 15:01 Go to previous messageGo to next message
Hi Wayne,
Thanks for the reply, I let you know how I get on with the radian diaphragms.
Best wishes,
Rog.
Re: JBL 2426 Replacement Diaphragms [message #37733 is a reply to message #37716] Fri, 09 August 2002 05:49 Go to previous message
Tom Brennan is currently offline  Tom Brennan
I've had very good results with Radians in both JBL and Altec drivers. A set of JBL 2470s I own had Radians installed by a JBL trained tech and were "bumped-in". A friend measured these and they measured as well as stock JBL aluminums.
Previous Topic: 16 ohm compression drivers
Next Topic: Wayne, you are the man!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Current Time: Mon Nov 23 01:21:44 CST 2026
