Home » Sponsored » Pi Speakers » Studio 2Pi redo
Studio 2Pi redo [message #37158] Thu, 04 July 2002 00:57 Go to next message
vladimir4 is currently offline  vladimir4
Hi Wayne,
I am happy user of 2Pi studio for 6 months now. My version
is built from a chip board and I am planning to make
a real box for it now.
I would like to build it from solid pinewood boards
(27mm = 1.1") as I had a good experience with it in the past.
My actual box is adjusted to the new Eminence Alpha 10 TS
params: my volume is 49 L (1.72 ft3) tuned to 32 Hz
using one tiny port 1.4" diam x 1.1" len.
I would like to ask you your opinion on the size for my
future box: should I keep my actual dimension or it will be better
to downsize it to your original 2Pi dimensions (is it
1.34 ft3/37.4 Hz ? ).
The actual bass response is so-so but present, so I wouldn't lost it.
But the most important is the midrange quality so if it will
be sacrified in a bigger box I prefer the smalest one and with less bass.
I have another box plans for Alpha 10: 88.6 L (3.13 ft3) tuned to 33Hz which is
supposed to optimize bass response (scarifying the power ability in the sub-100 Hz
region but this is not a big deal for my 20W amp).
Do you have any opinion on this configuration ?
Thanks in advance,
Vladimir
Re: Studio 2Pi redo [message #37160 is a reply to message #37158] Thu, 04 July 2002 01:53 Go to previous messageGo to next message
The Alpha 10 works nicely in cabinets from 40 to 160 liters tuned to 40Hz. Stay within that range and your speaker will sound great.
Thanks Wayne ! (nt) [message #37201 is a reply to message #37160] Sun, 07 July 2002 10:58 Go to previous message
nt
Previous Topic: Cabinetry
Next Topic: Bassport for 1 Pi.
Current Time: Thu Nov 26 12:30:31 CST 2026
