Home » Sponsored » Pi Speakers » CTS piezo w/ Eminence Beta coax?
CTS piezo w/ Eminence Beta coax? [message #36984] Wed, 19 June 2002 10:05 Go to next message
John Van is currently offline  John Van
Has anyone tried pairing a CTS piezo driver (maybe the KSN1142) with one of the Eminence Beta coaxial woofers? I'm thinking the Bets 10cx, at 97dB/1W/1m would be a great matchup.
Thanks.
Re: CTS piezo w/ Eminence Beta coax? [message #37011 is a reply to message #36984] Thu, 20 June 2002 10:13 Go to previous messageGo to next message
Sounds like that combination would make a good speaker. If you try it, let us know how it turns out.
Similar to two pi? [message #37012 is a reply to message #37011] Thu, 20 June 2002 11:05 Go to previous messageGo to next message
Sounds like I might just as well build your two pi. Can you send me plans? What does the kit include? Thanks.
Aha! [message #37013 is a reply to message #37012] Thu, 20 June 2002 11:19 Go to previous messageGo to next message
Okay, I just had to read the bottom of the page to find out what's in the kits. I'd still like the two pi plans, however. Thanks.
You've got mail! [message #37017 is a reply to message #37013] Thu, 20 June 2002 14:27 Go to previous message
Previous Topic: Plans for Thermionic three Pi?
Next Topic: 8-ohm, 90dB/W/m sub recommendation?
Current Time: Mon Oct 26 02:49:01 CDT 2026
