Home » Sponsored » Pi Speakers » question about applying veneer
question about applying veneer [message #36515] Sat, 18 May 2002 16:33 Go to next message
ray99 is currently offline  ray99
Hi. I saw some relatively inexpensive veneer at Home Depot. Is it simply a matter of cutting to fit, applying contact glue and then trimming with a router? I've heard about "bubbling" but Im not sure what this means. Thanks for any tips. Ray
Re: question about applying veneer [message #36516 is a reply to message #36515] Sat, 18 May 2002 17:31 Go to previous message
Don't know what wood veneer HD might sell but if it's wood and unbacked, not for the faint hearted beginner. NBS backed is good with contact adhesive and of course plastic laminate like Formica, Wilson Art, etc.
Most problems are due to not using 2 coats of glue; waiting too long or too short a time to apply or application in too cold temps. Other than that it's just what you say.
Previous Topic: 4 Pi questions
Next Topic: group delay
Current Time: Sun Oct 25 10:09:31 CDT 2026
