Home » Sponsored » Pi Speakers » 7 pi and lots-of-windows question
7 pi and lots-of-windows question [message #36340] Wed, 08 May 2002 07:22 Go to next message
JLapaire is currently offline  JLapaire
Greetings all,
I'm adding an 11' x 21' x 8' high sunroom on to my house. I'd like to put speakers at one end and was wondering about the combination of 7 pi cornerhorns and 20' of glass on one wall. Ceiling is broken up marginally by partially exposed beams, floor will be tile or stone over two layers of 3/4" ply.
I have most of the components (Eminence) for a pair of 4 pis, which look a lot like the components for the 7 pi.
Will the glass suck up enough bass to nullify the advantage of the cornerhorns?
May I have the plans for the Theater and Stage 7 pi?
Thanks very much
John
You have mail! [message #36343 is a reply to message #36340] Wed, 08 May 2002 10:59 Go to previous messageGo to next message
Your glass situation is one that sometimes causes problems and sometimes not, depending on the installation, I suppose. In most cases, large glass panels have proven to be OK, and the most cases are sliding glass doors and bay windows. But I've also seen them be a problem rattling. How do they react to your sound system now?
Thanks Wayne [message #36360 is a reply to message #36343] Thu, 09 May 2002 03:14 Go to previous messageGo to next message
The glass isn't installed yet, but it'll be silicone-gasketed in place so it shouldn't (won't) rattle. The room dims seem OK for corner horns? I was concerned about standing waves with the length 2x the width.
Also, NICE GOING on the "Shopping Cart"! Prices are good, and the one-stop shopping is right on. Couldn't find PI decals, though, how do I go about acquiring a couple of those?
Thanks again for the plans.
John
Re: Thanks Wayne [message #36369 is a reply to message #36360] Thu, 09 May 2002 11:34 Go to previous message
"π" logo decals are included with every kit. If you just want the decals - Please E-Mail me off-forum and tell me your postal address and I'll send you a couple of them.
Previous Topic: L-Pad Calc
Next Topic: "Shopping Cart" is online!
Current Time: Sun Oct 18 07:15:04 CDT 2026
