Home » Sponsored » Pi Speakers » Re: Xmax of bass speakers
Re: Xmax of bass speakers [message #36263] Sat, 04 May 2002 09:20
Xmax is a pretty loose term these days.
Mechanical excursion is how far the cone can actually move before the surround/spider rips or just stops cone motion. It's referred to usually as xmech.
Xmax is one-way *linear* excursion. It used to be defined as voice coil height - gap height/2. These days, companies measure it all different ways with all the new "long gap, longer coil" woofers coming out. Eminence has at least stayed tried and true and measures xmax by voice coil overhang. So you'll have a true, linear xmax of 3mm plus a bit of non-linear play as well.
Adam
Previous Topic: Where to find 4-PI building plan for JBL 2227H ?
Next Topic: HELP on mating Pioneer B20FU20-51FW with Motorola KSN-1038A Piezo
Current Time: Sun Nov 29 09:08:08 CST 2026
