Home » Sponsored » Pi Speakers » Speaker Plans
Speaker Plans [message #36002] Wed, 17 April 2002 11:23 Go to next message
Keith Wallang is currently offline  Keith Wallang
Hi!
I am in need of Bass Reflex Speaker Plans for Peavey 1505DT-8 Black Widow, speakers.
Thanks,
Keith
Re: Speaker Plans [message #36012 is a reply to message #36002] Wed, 17 April 2002 14:50 Go to previous message
My guess is that speaker would work well in a Stage four π cabinet, but you might want to check the electro-mechanical parameters of the driver to be sure. Put the specs of the Peavey driver into PiAlign and it will tell you the dimensions required for the cabinet and port. Be sure to read the "readme.txt" file contained in the distribution, because it gives instructions for operating the program and entering driver parameters. I might also recommend that you read the PiAlign.doc whitepaper contained in the distribution archive as well.
Previous Topic: How to post picture here?
Next Topic: Question for Wayne
Current Time: Tue Oct 20 11:19:19 CDT 2026
