Home » Sponsored » Pi Speakers » Professional Series Seven pi-18 speaker question
Professional Series Seven pi-18 speaker question [message #35956] Sat, 13 April 2002 07:55 Go to next message
GJP60 is currently offline  GJP60
Hi,
Getting started on building the boxes when I discovered the corners that these speakers will be placed in have baseboard heating running thru them. They're 8 inches high and extend out about 3.5 inches and impossible to move.
Could I extend the front and first set of side panels(without changing the box dimensions) say 9-10 inches past where they meet the bottom panel? Would this gap have a negative impact on the sound? Or would some kind of solid base be more practical? Any suggestions would be most appreciated.
Regards,
Gerry Provenzale
Raised hardwood floors [message #35960 is a reply to message #35956] Sat, 13 April 2002 19:16 Go to previous message
I'm not sure what you are saying, but if it involves slight changes to cabinet proportions - keeping volume the same - it's probably OK. I'm more concerned with the cavity that might be under the floor - Do you have a raised hardwood floor? That's what really concerns me 'cause they can muddy the sound and be hard to deal with.
Previous Topic: 1600 HZ crossover (4 Pi)
Next Topic: Wayne, I just can't downsize.........
Current Time: Wed Oct 21 01:39:38 CDT 2026
