Home » Sponsored » Pi Speakers » Wayne, did you get my re-mail???
Wayne, did you get my re-mail??? [message #35719] Thu, 28 March 2002 03:53 Go to next message
Erik from Holland is currently offline  Erik from Holland
Hi wayne,
I mailed back a reply to your mail. i plan on take this evening, tomorrow and saturday for finishing my new subs.
when my girlfriend is kind enough to iron the big mountains of laundry that are over my current system, i will take some pics and place them in the forum here saturday i think.
When i place photo`s, tell be of:
my first subs (ravemaster subwoofer kits)
my first mid-high kabinets (fane-based)
My current subs: eminence kappa 15 LF basreflex (own design)
My current mid-high`s: Ap....e Ae5 clone
My current running project: very fat subs, double l15/554K
My cat
Me
No, not my girlfriend!
So, till then
Yes, I got your mail; Sent a reply too [message #35721 is a reply to message #35719] Thu, 28 March 2002 09:27 Go to previous message
Yes, I sent you a reply. Check your mail; I've sent plans for Theater Series four π speakers.
Please note that this design uses the Eminence Delta 15 woofer/midrange and not the Kappa 15LF. As I mentioned in my first reply to you, I do not have plans drawn for a speaker containing a Kappa series driver. If you want to use a Kappa 15LF woofer, you may find that a different box and port is better suited. You should also examine the response curve and consider whether the drivers you've chosen are suitable for a two-way design. Many of the large-format Eminence woofers are, but I find that the LF-suffixed parts sometimes aren't. After finding a suitable woofer/midrange, I would design the speaker cabinet with PiAlign and model it with BoxPlot to confirm the design and see its response curve.
Previous Topic: I got my horns today, Wow! these speakers rock!!
Next Topic: My new speakers arrived today
Current Time: Thu Nov 26 06:07:26 CST 2026
