Home » Sponsored » Pi Speakers » Theater 4 Pi costs
Theater 4 Pi costs [message #35612] Thu, 21 March 2002 01:04 Go to next message
dbeardsl is currently offline  dbeardsl
I drew up a list of costs for the 4 Pi's I'm planning. Just the raw stuff, I'm getting for about $320 for both speakers. With shipping and a few other things I estimated it to be about $420, everything included(wood, glue, screws...), I'll probably spend about $500.
Here it is.
Item Stock# Quan. Price Total
IMAGE COMMUNICATION
Delta 15A (Woofer) 2 $51.54 $103.08
PSD2002 (Tweeter) 2 $47.31 $94.62
HT 290 (Horn Flares) 2 $23.50 $47.00
PXB2 1K6 (Crossover) 2 $24.16 $48.32
GOLDMINE ELECTRONICS
R1 and R2 (16 ohm) 4 - 68ohm 25W in parallel (per component)
G8817 20 $0.33 $6.67
R3 (9.315 ohm) 7 - 68ohm 25W in parallel
G8817 14 $0.33 $4.67
PARTS EXPRESS
C5 Dayton 20uF - 250V Polyropolene Capacitor
027-436 2 $4.95 $9.90
C1 (.47 uF) Dayton .47uF 400V Bypass Film-Foil Cap
027-458 2 $1.38 $2.76
Total $317.01
Re: Theater 4 Pi costs [message #35615 is a reply to message #35612] Thu, 21 March 2002 04:51 Go to previous messageGo to next message
Not Bad! I think that including Baltic birch ply and cherry veneer I spent as total of about $700. Most parts came from Parts Express. (This is just a crude estimate.)
Re: Theater 4 Pi costs - you saved a bit [message #35617 is a reply to message #35612] Thu, 21 March 2002 06:16 Go to previous messageGo to next message
freddyi is currently offline  freddyi
Danny - you now have the option of building those 4-Pi for a bit cheaper with your new JBL M252-8 JBL 15" (thats what ya get) - how does the Eminence Delta 15 sound?
Freddy
Hmm, how high does the M252-8B2 go? [message #35620 is a reply to message #35617] Thu, 21 March 2002 10:09 Go to previous messageGo to next message
I hadn't given it much thought, but yeah I could make the 4 Pi's out of them 252's... I haven't got them yet, and I haven't ordered the deltas.
anybody know of a response graph for the 252?, think it might be similar to the 151 or 222?
Re: Hmm, how high does the M252-8B2 go? [message #35621 is a reply to message #35620] Thu, 21 March 2002 10:25 Go to previous messageGo to next message
Danny - 'think' Rex Mills said he used 2Khz xover and it replaced woofer in 3677 sounding better - must not be too shabby - you might call JBL pro and ask:
818-894-8850
Freddy
the question is, can you live with the 13 cu.ft. [message #35622 is a reply to message #35620] Thu, 21 March 2002 10:46 Go to previous messageGo to next message
enclosure that boxplot advises? Sam
Well, I did some purchasing [message #35624 is a reply to message #35612] Thu, 21 March 2002 13:07 Go to previous messageGo to next message
I called up and ordered everything I needed for them 4 Pi's, minus the wood.
Also, I never got a reply on the Tent sale order I placed, and they didn't charge my credit card, so I ordered again 2 M252-8B2's.
Re: the question is, can you live with the 13 cu.ft. - how 'bout 2.2? [message #35628 is a reply to message #35622] Thu, 21 March 2002 16:39 Go to previous messageGo to next message
Hi Sam -
that woof can work with f10@50 (~86dB @50) in a 2.2cu.ft. sealed box - no stuffing - BB4 is ~7.5cu.ft. with bump cause tuned to fs - think yu could tune a bit lower and use lotsa fiberglass loining 'ala VMPS to get rid of bump but still keep some cone damping in 28-42hz region - Rex said it sounded better than 3677 woof - what 15" is in that one? - am confused by JBL export drivers
Freddy
Kits! [message #35646 is a reply to message #35612] Fri, 22 March 2002 10:46 Go to previous messageGo to next message
I just got my price sheet from Eminence - I'm negotiating with them about becoming a dealer. I still need to contact some other vendors, but I can already see that I'll be able to be price competitive.
So soon I'll be offering kits.
Re: Kits! [message #35647 is a reply to message #35646] Fri, 22 March 2002 11:42 Go to previous messageGo to previous message
Edwin is currently offline  Edwin
That sure is good news. Now I have something to look forward too!
Edwin
Previous Topic: placement of 4 Pi
Next Topic: Update for audiofest
Current Time: Fri Oct 16 00:44:36 CDT 2026
