Home » Sponsored » Pi Speakers » Spice revisited
Spice revisited [message #35437] Mon, 11 March 2002 14:16 Go to next message
dbeardsl is currently offline  dbeardsl
When generating a spice model for a linear motor, how do you calculate what to use to emulate the mechanical reactance.
i.e. For the Beta 12. mechanical reactance is 50hz Q is 5.82. How would you calculate the appropriate component values?
Re: Spice revisited [message #35438 is a reply to message #35437] Mon, 11 March 2002 15:47 Go to previous messageGo to next message
To calculate the equivalent LCR electrical circuit for mechanical resonance, find Zmax, and set the shunt resistance equal to that. Then find inductance and capacitance values equal to the (Zmax) resistance divided by the Q at the resonant frequency.
Re: Thanks! (nt) [message #35439 is a reply to message #35438] Mon, 11 March 2002 15:57 Go to previous message
nt
Previous Topic: ballpark Eq/comp for PV CH2?
Next Topic: Listening to Theater 4's and Wayne's Bracing Photo
Current Time: Sat Oct 24 17:40:32 CDT 2026
