Home » Sponsored » Pi Speakers » 207-100 vs. 270-014
207-100 vs. 270-014 [message #35386] Sat, 09 March 2002 15:18 Go to next message
dbeardsl is currently offline  dbeardsl
Eh?
These look the same and have PN #1165... are they the same just with different labels? or is the pyle a CTS knock-off?
Links to PE #'s (272-100, 270-014) [message #35387 is a reply to message #35386] Sat, 09 March 2002 15:21 Go to previous messageGo to next message
272-100
Re: Links to PE #'s (272-100, 270-014) [message #35388 is a reply to message #35387] Sat, 09 March 2002 15:28 Go to previous messageGo to next message
Pyle is now owned by Pyramid and they do not manufacture any product. theyre U.S.A made speakers are Eminence and chinese stuff is outsourced. it's a strong bet Motorola makes that tweeter or else it's a chinese knockoff.
cheers,
george
Re: 207-100 vs. 270-014 [message #35411 is a reply to message #35386] Sun, 10 March 2002 08:01 Go to previous message
I bought the Pyle pair (3 actually) a while ago. They don't
have the protection circuit, and if the freq. response does
to go 30KHz, its down a few dB, because they don't sound like
it. Nothing on them says Motorola nor CTS. When I buy some
more, I'll get the CTS/Moto versions. They don't sound bad,
but I expected a little more based on the comments others
have posted about the CTS 1165's. You can't complain too
much for $5-6$ each.
Chris
Previous Topic: Celestion Frontline pa drivers
Next Topic: 2,3,4 ?
Current Time: Wed Oct 14 17:15:41 CDT 2026
