Home » Sponsored » Pi Speakers » Eminence 12lt to ksn1188 steep crossover
Eminence 12lt to ksn1188 steep crossover [message #35251] Wed, 27 February 2002 11:36 Go to next message
mhammill is currently offline  mhammill
Greetings,
I just did some in room measurements with a Motorola ksn1188 with a 5x15 CH-3 copy horn in order to choose a crossover to pialigned eminence 12LT woffers I already own.
Theses were my results based on the average efficientcy.
800hz FLAT
630hz FLAT
500hz -18db
400hz -27db
315hz -31db
These measurements were consistant in both near feild and my normal listening seat with the speakers in 3 differant locations, I also used a reference set of speakers to check for any room interactions and found none (in this frequency range),I was very suprized to see these horns went that low and rolled off that steep. The only real problem I found was a dip at about 5khz that showed up in all the tests.
Here's my question, using the natural roll off of this horn and a crossover on the 12LT woofer only I've heard of 12db crossovers at 700hz used with this tweeter positive results, would it be wise to try a higher order crossover at about 500hz,and if so what are some suggested values for the components based on my test.
Thank's
Mike H.
Re: Eminence 12lt to ksn1188 steep crossover [message #35267 is a reply to message #35251] Thu, 28 February 2002 09:31 Go to previous message
If you are using a PartsExpress horn, what is the part number?
Also, is the 5KHz dip audible? Annoying?
What's your opinion overall on the setup?
Previous Topic: Pi 2's with Bottlehead Paramour Review
Next Topic: Well, had an incident...
Current Time: Wed Oct 14 00:18:38 CDT 2026
