Home » Sponsored » Pi Speakers » 800hz ksn1188 fourPi alpha crossover an horn
800hz ksn1188 fourPi alpha crossover an horn [message #35163] Wed, 20 February 2002 10:06 Go to next message
mhammill is currently offline  mhammill
Because of cost issues and just because it sounds like a good idea I would like to try a 800hz crossover from a alpha15 and use the natual roll off of a ksn1188.
Could I use one of the woofer only sections of the standard designs or do I need to start from scratch.
The efficiency seems right and I know Andy has the responce curves for the 1188, this my have already been discussed but I would like to hear the newest thoughts on this idea.
Also I assume I need to go with a 5x15 horn to get down to 800hz, which ones will work (cost?)
Thank's again,
MikeH.
Re: 800hz ksn1188 fourPi alpha crossover an horn [message #35164 is a reply to message #35163] Wed, 20 February 2002 10:33 Go to previous message
Sounds like a good plan. Just remember, you'll need a big box or an open baffle to use the Alpha 15.
Previous Topic: How do you guys do your measurements??
Next Topic: Crossovers on onePi and twoPi?
Current Time: Sun Oct 18 21:42:48 CDT 2026
