Home » Sponsored » Pi Speakers » tweeter compensation in active set-up
Re: does your active xover have HF eq built in? [message #35101 is a reply to message #35092] Tue, 12 February 2002 12:37 Go to previous messageGo to next message
The side walls of the CH-3 are straight, forming a constant 90o pattern in the horizontal plane. Thus, the on-axis response tends to track the driver's power response. Not completely, because the vertical pattern isn't CD. But enough that top octave compensation is necessary.
Re: does your active xover have HF eq built in? [message #35110 is a reply to message #35095] Tue, 12 February 2002 16:17 Go to previous message
Look through your manuals because I think your crossover has an option for CD equalization. That's what you want. If not, you'll need to find another way to add EQ.
Previous Topic: More active crossover questions
Next Topic: Day Two in the Life of a 4 Pi
Current Time: Sat Sep 05 07:10:13 CDT 2026
