Home » Sponsored » Pi Speakers » jbl single 2035H vs. dual 2226J shootout
jbl single 2035H vs. dual 2226J shootout [message #35046] Fri, 08 February 2002 12:15 Go to next message
Well, time to settle some questions about driver sensitivity. Both systems were measured with the rat meter on a tripod, @ one meter, on axis w/ the upper driver, raw readings "uncorrected". Beckman dmm was used to measure 2.83 vrms at the speaker terminals, into the nominal 8 ohm loads presented. The lower 2035 was disconnected, so this is a SINGLE 2035H vs. DUAL 2226J's, both in identical 4508 enclosures, 8 cu. ft. tuned to 40 Hz.
single 2035H:
50 Hz. 90 dB
60 Hz. 97.5 dB
100 Hz. 102.5 dB
nasty dip to 50 dB @ 235 Hz...floor bounce?
500 Hz. 102 dB
600 Hz. 102 dB
700 Hz. 99 dB
800 Hz. 99 dB
900 Hz. 106 dB
1000 Hz. 107 dB
dual 2226J's:
30 Hz. 86 dB
40 Hz. 92 dB
50 Hz. 96 dB
60 Hz. 95 dB
100 Hz. 100 dB
400 Hz. 101 dB
500 Hz. 99 dB
600 Hz. 99 dB
700 hz. 100 dB
800 Hz. 82 dB jbl data shows a dip here also
dip at 810 Hz. to 76 dB
900 Hz. 100 dB
1000 Hz. 101 dB
So I'd call the dual 2226J's a 100 dB system TOGETHER...implying a single 2226J would be 97 dB? 94dB?
From 100 Hz. to 800 Hz., the 2035 is sure giving it's big brother a good contest. It's an honest 100 dB, 8 ohm driver. And appears to be fully capable of "keeping up with" my HT fronts using the 4648A-8's.
Fun trivia...I can hardly hear 30 Hz. at 86 dB, you can sort of sense it...but the 4648A-8 will blow out my bic lighter at 6 inches away from the port...lots of air moving with a single watt input. Sam has a headache, and I wore 32 dB ear muffs, guess my skull is thin and sound got inside anyway :(
How the hell much does jbl have to pay people to stand around and input 100 watts and higher into these things? I must be getting old. Like Leonard Cohen said..."my parts that used to play, now hurt me instead". Or something like that. Sam
Re: jbl single 2035H vs. dual 2226J shootout - did you check Re? [message #35062 is a reply to message #35046] Sat, 09 February 2002 18:20 Go to previous messageGo to next message
freddyi is currently offline  freddyi
Hi Sam
JBL's spec sheet lists 3.9 ohm for 2035 dcr- so assumed they were wired in series - what's the story on 2035 dcr? - would help resolve sensitivity issue
Freddy
4638 system uses parallel wiring, [message #35063 is a reply to message #35062] Sun, 10 February 2002 07:27 Go to previous message
so the SYSTEM z with two 8 ohm nominal drivers is rated as 4 ohms. I tested sensitivity with a single 2035H, ie one 8 ohm driver, connected to the amp. 2.83 volts, at the driver terminals, into a nominal 8 ohm z. But the v.c. DCR is 3.95 ohms. The 4638 system, with both drivers hooked up, was 2.0 ohms DCR, maybe a tough load for some amps, but who cares cause this one is being chopped up as a "donor" for woofers in my Pseudo 4 Pi Pro rear surrounds. Sam
Previous Topic: Seven Pi-18 or Ten Pi-18(long)
Next Topic: Re:pi4
Current Time: Mon Oct 26 15:17:23 CDT 2026
