Home » Sponsored » Pi Speakers » PSD 2001
PSD 2001 [message #34880] Fri, 25 January 2002 09:06 Go to next message
Hey, does anybody have experience with the PSD 2001? I have lots with the 2002's, but i need a compression driver that'll go down to 1 kHz without getting stressed at moderate listening levels. It's shown as going down to 1 kHz, but it also seems nearly identical to the 2002. So I'm just wondering how it sounds and if it can go that low without problems.
I want to cross it third order with a Kappa 18A.
Thanks
Adam
Re: MD 2001 [message #34882 is a reply to message #34880] Fri, 25 January 2002 11:44 Go to previous messageGo to next message
Assuming you're actually talking about the Eminence MD2001, that's one of the compression drivers I used until early last year. The link below lists several posts about it.
Re: PSD 2001 [message #34886 is a reply to message #34880] Fri, 25 January 2002 13:58 Go to previous message
Adam E-mail me off forum ...I want to talk to you about the Kappa's
Kelly
k.j.morrison@home.com
Previous Topic: Any opinions on the components from JBLs 3677s
Next Topic: Is it true you can damage your hearing if ya exposed to over 90 db
Current Time: Tue Nov 03 13:55:39 CST 2026
