Home » Sponsored » Pi Speakers » Bolt on horns/ drver for 4 Pi's- What Bolts?
Bolt on horns/ drver for 4 Pi's- What Bolts? [message #34785] Thu, 17 January 2002 06:17 Go to next message
Is there a particular size bolt to use for the 2002 Eminence and the H290 horn?
Garland
Re: Bolt on horns/ drver for 4 Pi's- What Bolts? [message #34794 is a reply to message #34785] Thu, 17 January 2002 15:59 Go to previous messageGo to next message
hi garland, can't remember the size i used. i just took the driver with me into home depot and tried various bolts.
cheers,
george
1/4"-20 x 3/4" [message #34795 is a reply to message #34785] Thu, 17 January 2002 16:14 Go to previous message
The thread pattern used on the opposing pair of mounting holes is 1/4" diameter and has 20 threads per inch. The best length I've found is usually 3/4" because a 1/2" long bolt usually only "grabs" with one or two threads, if it reaches at all, and a 1" long bolt usually bottoms out. On some horns or adapters, you might need this long of a bolt, but then again, on many of them (like the H290), you have limited space to insert the bolt, so you must use a short bolt just to get it started.
Previous Topic: More Midwest Audio gathering stuff!
Next Topic: piezo
Current Time: Thu Nov 12 16:19:55 CST 2026
