Home » Sponsored » Pi Speakers » 2226H vs Delta 15
2226H vs Delta 15 [message #34769] Wed, 16 January 2002 06:35 Go to next message
Frode is currently offline  Frode
In an earlier post you wrote (about the 2226H):
You can make the cabinet anything from about 2.5 cubic feet to 5 cubic feet, and have tuning anywhere from about 38Hz to maybe 50Hz, and still have an acceptable speaker.
I know that you recommend PiAligned cabinets, but how would a 2226H in a 4.5-5 cu.ft. box tuned to 40-42Hz perform compared to a 4 Pi with the Delta 15?
By the way, my Beymas drivers sounds real nice. I still haven't changed the filter from the MD2001, so I reckon they'll get even better. I've also bought a set of Oris horns. I can't afford the Lowther drivers for these yet, so I've decided to order a pair of Beta 8CX instead. My 4Pi will be used for bass.
Frode
Re: 2226H vs Delta 15 [message #34772 is a reply to message #34769] Wed, 16 January 2002 13:48 Go to previous message
I would prefer the JBL 2226H over the Delta 15 even if the box chosen for each woofer were tuned max flat. The reason is the JBL 2226 has a shorting ring and so it distorts less. But beyond that, a JBL 2226 is perfect in a 2.5ft3 - 5.0ft3 while this size is much too small for a Delta 15. The JBL will be nice and smooth in a 4.5ft3 box but the Delta 15 will be underdamped. So I'd go with the JBL's.
Previous Topic: Rear ports for PA speakers?
Next Topic: exteme bass drowning out treble and midrange
Current Time: Fri Nov 27 07:40:56 CST 2026
