Home » Sponsored » Pi Speakers » No 4pi
No 4pi [message #34724] Sun, 13 January 2002 08:47 Go to next message
JLapaire is currently offline  JLapaire
Well, fortunately I did this before ordering components, but still...
I made a cardboard mockup of the Theater 4pi and tried to fit it into the living room. I could fit one, but not two, so they're out.
I know you're probably gonna heave a great big sigh, Wayne, or any of you other seasoned pi-ers, but here it is -
Since the Theater 3 is about the biggest box I can do, how do they compare with the Pro or Premium Stage 4s, or for that matter the Premium Studio 2? They all seem to have a 30 or 40hz bottom, 18 to 20khz top, similar dB/watt. I want a smooth, coherent speaker with some slam, and 5 cu ft is the max. What's a guy to do?
Thanks for bearing with me.
John
Professional Series [message #34728 is a reply to message #34724] Sun, 13 January 2002 12:35 Go to previous message
The Professional Series speakers are the best ones. They generate less distortion and are cleaner sounding as a result. If you can afford them, that's the way to go.
Previous Topic: Any designs with Eminence Kappa woofers?
Next Topic: A couple questions about Pi designs...
Current Time: Thu Nov 19 11:34:28 CST 2026
