Home » Sponsored » Pi Speakers » Any designs with Eminence Kappa woofers?
Any designs with Eminence Kappa woofers? [message #34701] Sat, 12 January 2002 07:58 Go to next message
RyanH is currently offline  RyanH
Hi,
I was wondering if any of the designs would work with Eminence Kappa drivers (the Pro 15 by the way). I can get these for a very reasonable price and would very much like to use them. The box design isn't a problem, but the crossover is. I just want to make sure the crossover will work well with them. Thanks!
--Ryan
Also... [message #34702 is a reply to message #34701] Sat, 12 January 2002 08:01 Go to previous messageGo to next message
Acutally any of the Kappa 15s would work: regular Kappa 15A, Kappa 15LFA, or the Pro. Thanks again in advance for any replies.
--Ryan
Re: Also... [message #34704 is a reply to message #34702] Sat, 12 January 2002 10:04 Go to previous messageGo to next message
me... I have four 15lfa's. Very nice woofers.
Adam
π crossover [message #34705 is a reply to message #34704] Sat, 12 January 2002 12:35 Go to previous messageGo to next message
I don't use Kappas but I think the crossover will work for it. I use the same basic crossover for several woofers, changing just the Zobel values. Values for the tweeter circuit are specific to the driver, but a chart is provided for use with different ones.
Re: π crossover [message #34725 is a reply to message #34705] Sun, 13 January 2002 09:05 Go to previous message
Thanks! This will be a huge help. While I cannot build it just yet (I will when semester is over) I will buy the woofers so that I don't have to worry about missing out when they run out. Thanks again for your great help!
--Ryan
Previous Topic: 10" phase plug
Next Topic: No 4pi
Current Time: Mon Oct 19 12:48:32 CDT 2026
