Home » Sponsored » Pi Speakers » Parts for Theater 4 Pi?
Parts for Theater 4 Pi? [message #34569] Fri, 28 December 2001 21:11 Go to next message
craigha@attbi.com is currently offline  craigha@attbi.com
I've taken a fancy to building a Theater 4 Pi
and want to find prices on the needed parts.
At http://www.partsexpress.com/ I found these
components:
EMINENCE DELTA-15A 15" DRIVER 8 OHM. Catalog # 290-418
EMINENCE pxb-1k6 HIGH PASS CROSSOVER BOARD 1,600 Hz. Catalog # 290-600
EMINENCE H290 HORN LENS BI-RADIAL 90x40. Catalog # 290-554
EMINENCE PSD2002-8 HORN DRIVER 3 BOLT 8 OHM. Catalog # 290-442
Are these correct?
Thanks.
Re: Parts for Theater 4 Pi? [message #34574 is a reply to message #34569] Fri, 28 December 2001 22:32 Go to previous messageGo to next message
The pxbII-1K6 crossover, Parts Express part number 290-634 should be procured rather than the one you've shown. The one you list is a high pass (tweeter) filter only and the one I've suggested is a two-way (woofer/tweeter) filter.
Also, you'll need:
019-020 8 ohm 100W non-inductive resistor (R3 - one per speaker)
027-436 20uF, 250V polypropylene capacitor (C5 - one per speaker)
004-016 16 ohm, 10W non-inductive resistor (R1 & R2 - eight per speaker, combined as series/parallel network)
027-458 0.47, 400V polypropylene bypass capacitor (C1 - one per speaker)
Re: Thanks. nt [message #34577 is a reply to message #34574] Sat, 29 December 2001 06:45 Go to previous messageGo to next message
nt.
Parts kit prices? [message #34578 is a reply to message #34574] Sat, 29 December 2001 07:04 Go to previous messageGo to next message
I came up with a raw parts cost of about $221
for one Theater 4 Pi. Does this look correct?
All from http://www.partsexpress.com
290-418 Eminence Delta 15A $67
290-442 Eminence PSD2002 $62
290-554 Eminence H290 horn $30
290-634 Eminence pxb2-1k6 crossover $32
67 + 62 + 30 + 32 = 191
Separate crossover parts
019-020 8 ohm 100W non-inductive resistor (R3 - one per speaker) $11.50
027-436 20uF, 250V polypropylene capacitor (C5 - one per speaker) $4.95
004-16 16 ohm, 10W non-inductive resistor (R1 & R2 - eight per speaker) $1.50
027-458 0.47, 400V polypropylene bypass capacitor (C1 - one per speaker) $1.38
11.50 + 5 + (8*1.50) + 1.50 = $30
Total 191 + 30 = 221
Re: Parts kit prices? [message #34581 is a reply to message #34578] Sat, 29 December 2001 09:52 Go to previous messageGo to next message
I think that is about what I paid.
Garland
Re: Parts for Theater 4 Pi? [message #34589 is a reply to message #34574] Sun, 30 December 2001 02:04 Go to previous messageGo to next message
Check out Peavey CH-3 horn, looks better in proportion to cabinet.
Was the recommended horn when I built mine.
Online source for Peavey CH-3? [message #34592 is a reply to message #34589] Sun, 30 December 2001 05:04 Go to previous messageGo to next message
I don't see Peavey equipment at PartsExpress.
Do you know any online sources?
I live in Denver, CO and will track down pro. sound
dealers in the area.
Thanks
Re: Online source for Peavey CH-3? [message #34601 is a reply to message #34592] Sun, 30 December 2001 15:29 Go to previous message
Music Sound World in Tulsa, home of Professor Parham, himself.
Call Maury at 800-875-8663, they had stock when local dealers couldn't even order them.
Previous Topic: Hey Garland, Hey Wayne. Hey everyone.........
Next Topic: Budget Woes and 15" Woofer
Current Time: Thu Nov 26 04:18:52 CST 2026
