Home » Sponsored » Pi Speakers » ribbon tweeters
ribbon tweeters [message #34538] Tue, 25 December 2001 20:14 Go to next message
frozen is currently offline  frozen
Hi,
I have inquired previously about 1 and 2 pi's. My question is that both these designs use piezo tweeters, are ribbon tweeters an option or encouraged for these? My thoughts revolve around the dayton ribbon from parts express of the infinity ribbon from speaker city.
Thanks,
Brent
Re: ribbon tweeters [message #34540 is a reply to message #34538] Tue, 25 December 2001 22:20 Go to previous messageGo to next message
I love the old Infinity EMIT tweeters. As a suggestion, try to find a JBL 2115, which is an 8" midwoofer. They're very nice sounding speakers. A JBL 2115 paired with an Infinity EMIT tweeter would make an excellent small speaker.
Re: ribbon tweeters [message #34544 is a reply to message #34538] Wed, 26 December 2001 08:31 Go to previous messageGo to next message
Hi Wayne,
Since the jbl 2115 is not readily available do you have any thoughts on the 8" pioneer Part# 290-045 from parts express for this application. I am looking for smallish speakers for a 2nd system powered by a st70 and foreplay.
Thanks,
Brent
Re: ribbon tweeters [message #34551 is a reply to message #34544] Wed, 26 December 2001 18:17 Go to previous messageGo to next message
I'd spend some time watching for JBL 2115's. I think they're worth the effort for what you're trying to do. If you can't find 2115's, you might try the Fostex F200A, which I think is a 2115 copy.
pioneer FR remarks for Brent [message #34555 is a reply to message #34540] Thu, 27 December 2001 05:52 Go to previous message
Brent,
I have some experience with this driver. The PE catalog specs are WRONG. Look on the Single driver forum for the correct ones. My examples (grey foam surround) are 94 dB @ 1kHz, and reasonably flat from 500 to 5000 Hz. Around 6 kHz, they have a sort of nasty 10 dB peak, which can be brought down with a notch filter. Above 6 kHz, they produce good output out to past 12 or 13 kHz. They play well at 100 dB levels, and are rated for 60 watts, in spite of their rather limited Xmax.
Another similar unit you might consider is the pioneer 8 in. WOOFER, speced to play out to 7 kHz. (PE 290-042) with a 30 oz. magnet and vented pole piece...haven't played with them much yet, except to ascertain the Fs and z plot. Sam
Previous Topic: Thermonic 3pi substitute?
Next Topic: Hello Wayne Is the Compensation on 2370 same as 2342 0r 44 horn?
Current Time: Sat Oct 17 20:03:38 CDT 2026
