Home » Sponsored » Pi Speakers » resistor
resistor [message #34103] Sun, 28 October 2001 10:14 Go to next message
Zeno is currently offline  Zeno
wayne is it important to follow the value of the watts of the resistors in the crossover for the pi 4? i hope that this is not a very stupid question, because my friend told me it is o.k as long as i follow the value of the Ohm
zeno
Resistor power dissipation requirements [message #34104 is a reply to message #34103] Sun, 28 October 2001 10:53 Go to previous message
The power rating of resistors is important if you want to be able to use the speakers with a powerful amp. If you always use a low-power amp, you can use resistors with lower power limits. As long as the resistance value is the same, the response curve will be the same.
Previous Topic: crossover for Altec 604-8G
Next Topic: How do you test speaker spl?
Current Time: Wed Oct 21 07:36:50 CDT 2026
