Home » Sponsored » Pi Speakers » Which drivers are suitable for Pi alignment?
Which drivers are suitable for Pi alignment? [message #33972] Sat, 29 September 2001 14:30 Go to next message
Frode is currently offline  Frode
I've been playing around with PiAlign for a while now, and was wondering if there are some qualities or parametres that make a driver more suitable for this alignment than others. Some designs makes more sense than others.
TIA
Frode
Pi Alignments compared with B4, C4 and QB3, revisited [message #33977 is a reply to message #33972] Sat, 29 September 2001 16:50 Go to previous message
The Pi Alignment Theory describes a method for determining motor cabinet volume and tuning for any woofer. The cabinets it suggests are very similar to Davies' 1981 implementation of Thiele/Small analysis, so this is like asking whether there are some drivers that are more suitable to Thiele/Small analysis than others. In fact, the tuning could be said to be in exact agreement because Pi alignments place it at 0.375Fts/Qts and Davies' is 0.37Fts/Qts. Not much difference. This is an example of two very different methodologies providing two very similar results and it tends to confirm both.
Previous Topic: Yellow glue: the good, the bad ......
Next Topic: Pi Aligned Afterburner & Port Calculation
Current Time: Thu Nov 12 03:47:50 CST 2026
