Home » Sponsored » Pi Speakers » Pi Align
Pi Align [message #33963] Fri, 28 September 2001 16:34 Go to next message
boblaz@yahoo.com is currently offline  boblaz@yahoo.com
I have run the numbers for the eminence delta 15 and the program is providing very odd numbers for the enclosure ie;
cabinet: motor parameters used:
encl type reflex
encl vol .2222222 lo cut 30
ideal fr 675 hi cut 1600
ideal q .5314961 eff 101
encl fr 127.9479 power 300
encl q .888889 impedence 8
encl ht 10.90272 quantity 1
encl wd 7.268482 vas 10.4
encl dp 4.845655 qd 45
frd 40
Using Pi Align [message #33964 is a reply to message #33963] Fri, 28 September 2001 19:27 Go to previous messageGo to next message
Please read the "readme.txt" file contained in the distribution archive. This will tell you the proper format for the variables used by PiAlign. There are a few things that are commonly mistaken:
1. All dimensions use Imperial units, i.e. inches, feet, etc.
2. Not all are the same unit in the PiAlign program. Ve is in cubic feet but port dimensions are in inches and sq. inches. Cabinet dimensions are also in inches. The formulas on the Pi Alignment Theory whitepaper all "expect" units to be normalized to the same units, but the program uses those that are most common for the given term.
3. Vad=Vas, Frd=Fts and Qd=1/Qts. Note that Qd is not the same as Qts.
I am certain that one of these is the reason why your results were incorrect.
Re: Using Pi Align [message #33968 is a reply to message #33964] Sat, 29 September 2001 06:03 Go to previous message
Thanks!!! It is working now. I failed to compute Qd properly.
Previous Topic: XO-slope for sub
Next Topic: Power
Current Time: Tue Aug 11 21:05:33 CDT 2026
