Home » Sponsored » Pi Speakers » Where to source port for Theatre 4's?
Where to source port for Theatre 4's? [message #33865] Mon, 17 September 2001 15:08 Go to next message
Been thru the pages, got my veneer and MDF ready, waiting for the speakers but I can't seem to find the proper size port off the shelf. Something was posted about carpet cardboard tubes but they differ in size from the working drawing. A little help?
Re: Where to source port for Theatre 4's? [message #33867 is a reply to message #33865] Mon, 17 September 2001 18:16 Go to previous messageGo to next message
James W. Johnson is currently offline  James W. Johnson
Is it a 4" port?...If so Home Depot has tons of 4" PVC for cheap, and most carpet tubing is indeed 4" diameter.
4" port [message #33869 is a reply to message #33865] Mon, 17 September 2001 20:55 Go to previous message
The port is 4" dia. and 4" long. The material I use is cardboard mailing tube. It is available at any drafting or office supply shop. The outside diameter is 4", inside diameter is 3.84". It's perfect.
Previous Topic: port questions - pro pi7's
Next Topic: port dimensions - pro pi7
Current Time: Fri Oct 23 14:09:57 CDT 2026
