Home » Sponsored » Pi Speakers » JBL 2410 drivers
JBL 2410 drivers [message #33559] Sun, 15 July 2001 22:15 Go to next message
James W. Johnson is currently offline  James W. Johnson
How decent is the JBL 2410 driver? I noticed some on Ebay. I have decided to go the cheap route for the four Pis, I picked up a used pair of 2226H drivers for $350 and I also want to find used tweeters.
Re: JBL 2410 drivers [message #33560 is a reply to message #33559] Sun, 15 July 2001 23:45 Go to previous messageGo to next message
Yes, that driver will work. You might look at the Eminence PSD2002 too, because it costs about the same new as a used JBL driver. It's a pretty good driver, especially for the price.
Re: JBL 2410 drivers [message #33561 is a reply to message #33560] Mon, 16 July 2001 02:42 Go to previous messageGo to next message
Is this the proper version of the PSD2002 that I need?
Re: JBL 2410 drivers [message #33562 is a reply to message #33561] Mon, 16 July 2001 02:48 Go to previous messageGo to next message
By the way , at this point I don't have a choice because Parts Express has dropped the price of the PSD2002 to $61.01ea! and the H290 is only $29.11.
four Pi parts [message #33563 is a reply to message #33562] Mon, 16 July 2001 03:23 Go to previous messageGo to next message
That's the right driver, but you'll need to get the PSD2002 bolt-on version to mount on the H290 horn.
Re: four Pi parts [message #33564 is a reply to message #33563] Mon, 16 July 2001 08:52 Go to previous messageGo to next message
Thanks Wayne, I understand everything in the plans except the tweeter circuit..... Is this how you do it? -----0.47uF----- | | Crossover tweeter out (+) -------|------16ohm--------- Tweeter (+) | | 16ohm | | Crossover tweeter out (-) ---------------------------- Tweeter (-) Is this correct?
James
Re: four Pi parts [message #33565 is a reply to message #33564] Mon, 16 July 2001 08:59 Go to previous messageGo to next message
Doh, that's what the crossover shows. I meant to show you how I think I'm supposed to make each 16 ohm resistor: |----16ohm--------16ohm----| ---| |--- |----16ohm--------16ohm----| Is that right?
Re: four Pi parts [message #33566 is a reply to message #33565] Mon, 16 July 2001 09:23 Go to previous messageGo to next message
I went ahead and laid out the entire crossover on the bottom of the page of the following link, would you mind looking it over Wayne?
Thanks a lot , James
Re: four Pi parts [message #33568 is a reply to message #33566] Mon, 16 July 2001 12:44 Go to previous message
Yes, that's exactly how you do it.
Previous Topic: Extended bass response from small cabinets
Next Topic: hookup wire
Current Time: Thu Nov 19 06:45:34 CST 2026
