Home » Sponsored » Pi Speakers » Four Pi crossover question
Four Pi crossover question [message #33503] Sun, 01 July 2001 11:29 Go to next message
James W. Johnson is currently offline  James W. Johnson
First off I must say that I really like you Wayne!,you are one of the nicest speaker guys I have dealt with on the internet. Thanks for sending me the Pi decals and Four Pi plans, I cannot wait unil the day that I apply the decals... I have it all worked out, this is sort of my speaker building ritual.....
1. build the enclosures
2. finish the enclosures
3. build the crossovers
4. mount the drivers and crossovers
5. set up the speakers where I plan to use them
6. unplug my telephone
7. pour myself a cool drink
8. pick out a CD
9. apply the Pi decals
10. Listen to them for the first time.
For the tweeter circuit on my Four Pi crossovers, instead of using 16ohm 10watt resistors I would like to use 8ohm 100watt resistors for R1 and R2. two in series for each one. do you see any problems with this?
Four Pi crossover answer [message #33504 is a reply to message #33503] Sun, 01 July 2001 13:17 Go to previous message
Thanks for your kind words. Really! As for the resistors, that will work just fine.
Previous Topic: big improvement
Next Topic: PA horn scoop bins
Current Time: Mon Nov 09 19:00:25 CST 2026
