Home » Sponsored » Pi Speakers » Theater Seven Pi--so far so good!
Theater Seven Pi--so far so good! [message #33433] Mon, 18 June 2001 10:22 Go to next message
AudioLapDance is currently offline  AudioLapDance
Hi Wayne, Replay and y'all!
I finally started into my Theater 7 Pi s! I just built the box part of the corner horn (the rest is just a positioning device) and they are still monsters! I used 3/4 MDF and put #8, 1 1/2" particle board screws every 2 inches!!! Over kill I know, but they look like they have rivets around the outside-sort of an industrial / Mad Max look. I like it! I might even leave them unfinished!
Do I use 2" fiberglass insulation (pink, itchy stuff) on the walls adjacent to the port (all I can find so far are 3/4" insluated drop-ceiling tiles and 3.5" house insulation)? What type of screws do you prefer to mount the drivers?
Thanks,
Jeff
Re: Theater Seven Pi--so far so good! [message #33437 is a reply to message #33433] Tue, 19 June 2001 01:18 Go to previous message
Good work, Jeff!
I use R13 insulation for acoustic damping material and 1/4-20 screws and T-Nuts to mount the drivers.
Keep us posted on your progress!
Previous Topic: Pi Alignments compared with B4, C4 and QB3
Next Topic: Any thoughts about the Peavey 22XT?
Current Time: Thu Nov 19 12:06:14 CST 2026
