Home » Sponsored » Pi Speakers » Doghouse Pictures....
Doghouse Pictures.... [message #33078] Mon, 26 March 2001 18:49 Go to next message
jsalve is currently offline  jsalve
Thanks for the doghouse plans Wayne. ;)
With the right tools, it is not that hard to build. I used biscuits to join everything, very strong joints and no screws to hide. It took me a little longer to build because I am too cheap to buy all the clamps needed. It took me a few days to clamp everything together. But I am very happy with the results.
Still no woofer, but I should get it any day now. I will post my impressions here.
Jeff
seven Pi's - the MIGHTY TAD MAN [message #33079 is a reply to message #33078] Mon, 26 March 2001 20:35 Go to previous messageGo to next message
Good job! What wood stock did you choose?
Re: seven Pi's - the MIGHTY TAD MAN [message #33081 is a reply to message #33079] Mon, 26 March 2001 21:43 Go to previous messageGo to next message
It is made of 3/4 Baltic Birch with 2 braces under and over the woofers. It feels more solid than the last speaker I built with mdf and screws. Access to the enclosure is pretty easy, so adding more braces will not be a problem.
Re: seven Pi's - the MIGHTY TAD MAN [message #33082 is a reply to message #33081] Mon, 26 March 2001 22:22 Go to previous messageGo to next message
Sounds great! Keep us posted with your progress!
I thought, tweeters should face forward???nt [message #33083 is a reply to message #33078] Mon, 26 March 2001 22:31 Go to previous messageGo to next message
Eldragon is currently offline  Eldragon
nt
Re: I thought, tweeters should face forward???nt [message #33086 is a reply to message #33083] Mon, 26 March 2001 23:08 Go to previous messageGo to next message
eldragon,
I will put another horn to cover 300Hz and up on top of this cabinet.
Regards,
Jeff
That explains, ...thanx and good luck! nt [message #33096 is a reply to message #33086] Tue, 27 March 2001 11:20 Go to previous message
nt
Previous Topic: Hi...some questions...
Next Topic: Letter from Rob Gault, President of Eminence Speaker Corporation
Current Time: Tue Oct 20 17:15:06 CDT 2026
