Home » Audio » Group Build » So; Are we building this thing or what?
So; Are we building this thing or what? [message #32013] Fri, 22 September 2006 14:29 Go to next message
The Smithy; I know I could use some dialogue on it.
Re: So; Are we building this thing or what? [message #32014 is a reply to message #32013] Fri, 22 September 2006 16:01 Go to previous messageGo to next message
Are you still using Optimum Online 2 block?
Re: So; Are we building this thing or what? [message #32015 is a reply to message #32014] Fri, 22 September 2006 18:57 Go to previous messageGo to next message
Yes absolutely.
Thats Block2@optonline.net.
vanes here! [message #32016 is a reply to message #32013] Fri, 22 September 2006 19:52 Go to previous messageGo to next message
Got my vanes from Bill, look great. Now I just have to get going on the rest of it. Not for the next couple of weeks at least, unfortunately!
Re: vanes here! [message #32018 is a reply to message #32016] Sat, 23 September 2006 07:41 Go to previous messageGo to next message
Any ideas on how you will be cutting the flares yet?
Re: vanes here! [message #32020 is a reply to message #32018] Sat, 23 September 2006 09:31 Go to previous messageGo to next message
Not yet, need to figure that out, I guess.
Re: So; Are we building this thing or what? [message #32021 is a reply to message #32013] Sat, 23 September 2006 10:51 Go to previous messageGo to next message
Do you have the original article?
Re: vanes here! [message #32022 is a reply to message #32020] Sat, 23 September 2006 11:50 Go to previous messageGo to next message
Find a spoke shave at a flea market. Tune and sharpen it.
Cut the flare with a jigsaw or bowsaw and Plane the curve to the line with the spokeshave.
Or 3M #77 spray glue 60 grit paper on an 1 1/4" dowel. Shouldn't take much longer than the spokeshave. But it's such a satisfying tool to use.
I mostly use my Record convex one to smooth out speaker cut-outs after I've managed to have that freakin' dimple cut-out when the hole jig slips as the cut-out is completed.
Re: So; Are we building this thing or what? [message #32025 is a reply to message #32021] Sat, 23 September 2006 17:32 Go to previous messageGo to next message
Yep; you mean the one off Audioheritage right?
Re: vanes here! [message #32026 is a reply to message #32022] Sat, 23 September 2006 17:34 Go to previous messageGo to previous message
I like that; they have evidence of prehistoric man using spokeshaves? How can you beat it.
Previous Topic: 6A5 P-P # 2
Next Topic: 6A5 P-P #4
Current Time: Fri May 03 07:05:30 CDT 2024
