Home » Audio » Group Build » Smith Horn Group Build - Please Complete Survey
A bit of info [message #31976 is a reply to message #31967] Sat, 16 September 2006 04:37 Go to previous messageGo to next message
I have a pair of Visaton 1-inch throat adapters for their Smith horn.
The round inlet is 25mm (1 inch) diameter, measured with a scale.
The outlet is 42mm (1-5/8 inch) horizontal by 32mm (1-1/4 inch). vertical.
The transition distance is 70mm (2-3/4 inch) face-to-face.
If you use the Westlake-style adapter this won't make any diference, of course.
FWIW,
Charlie
You know you want to [message #31977 is a reply to message #31974] Sat, 16 September 2006 08:39 Go to previous messageGo to next message
Come on, Bill. Play with us. Pleeeeeease.......
Re: You know you want to [message #31978 is a reply to message #31977] Sat, 16 September 2006 08:44 Go to previous messageGo to next message
Yah. How long will it really take you to slap a couple of pieces of wood over the vanes?
Re: A bit of info [message #31980 is a reply to message #31976] Sat, 16 September 2006 22:45 Go to previous messageGo to next message
The 1.25" vertical outlet seems strange to me. The plans for smith horns I've seen all have a lower outlet than inlet.
For example, the JBL 2328 throat adaptor transitions 2" drivers down to 1-3/8" height into 2397 horns.
Re: A bit of info [message #31982 is a reply to message #31980] Sun, 17 September 2006 13:52 Go to previous messageGo to next message
That's why I posted it; on the off-chance somebody may find it significant. It certainly is diferent than the common understanding. The Visaton horn is 90mm thick O/A; by eye the height of the vanes looks at least 25mm.
Re: Smith Horn Group Build - Status please [message #32135 is a reply to message #31966] Sun, 14 January 2007 07:23 Go to previous message
Scholl is currently offline  Scholl
Is this build going forward. I'd be interested in a pair.
Smith Horns look good for MTM type designs.
THanks, Scott Scholl
Previous Topic: ART Array Kits
Next Topic: ART Array Kits - Anyone??
Current Time: Sun Apr 28 15:21:21 CDT 2024
