Home » Audio » Group Build » Pinging Doug - Peerless s-265
Pinging Doug - Peerless s-265 [message #31927] Tue, 18 July 2006 05:23 Go to next message
TOttman2 is currently offline  TOttman2
Hi Doug,
I hope you can help me with identifying the wires on my
Hayboer Peerless s-265 output transformer.
Here's the 9 wire colors I have coming from one side (primary?):
1. white (UL 1 ?)
2. white with stripe (UL 2 ?)
3. blue (plate 1 ?)
4. blue with stripe (plate 2 ?)
5. black (40% 1 ?)
6. black with stripe (40% 2 ?)
7. gray (?)
8. red (CT and b+ ?)
9. pink (?)
Is this a 10K PP transformer? And is the 10K from plate to plate?
Here's the 6 wires from the other side (secondary?):
1. black
2. black with stripe
3. yellow
4. yellow with stripe
5. green
6. green with strip
I need a 4 ohm and an 8 ohm output.
Thanks,
Tom
Re: Pinging Doug - Peerless s-265 [message #31928 is a reply to message #31927] Tue, 18 July 2006 14:04 Go to previous message
Hey Tom,
This is how they're colour coded:
Primary side connections from one anode to the other:
Grey---anode1
Blue---a1-40%
White---a1-30%
Black---a1-20%
Red---center tap
Black-Red stripe---a2-20%
White-Black stripe---a2-30%
Blue-Yellow stripe---a2-40%
Purple---anode2
Secondary takes output from the green and green/yellow for 8 and 16R. For 8 connect/strap the yellow and yellow/black and for 16 connect the black and black/white stripe. For 4R we put the two halves of the 16R winding in parallel.
They are 10k a-a, and rated for 40W. This is a bit conservative, as they've got 3.4 square inches of M6 core. At ~20W/in^2 they are more like 60W.
cheers,
Douglas
Previous Topic: C3g & D3a
Next Topic: C transformers cores colours marks
Current Time: Tue Apr 16 10:39:53 CDT 2024
