Home » Audio » Group Build » Removing volume pot
Removing volume pot [message #31234] Thu, 07 July 2005 08:25 Go to next message
Need to eliminate the volume pot from the SV811-10 amp. The schematic calls for a 100k pot. My question: Do I replace with a 100k ohm resistor from input/grid to ground, or is there a better value to use. I saw on another forum that someone suggested going with a 470k resistor when replacing a pot rated at 100k......Colin
Re: Removing volume pot [message #31235 is a reply to message #31234] Thu, 07 July 2005 10:12 Go to previous message
Brucie is currently offline  Brucie
I replaced with 100K just as you outlined. No problems.
Previous Topic: Don't forget about BOI
Next Topic: Guinevere Power Trans
Current Time: Fri Nov 06 11:50:29 CST 2026
