Home » Audio » Group Build » Pics of Guinevere
Pics of Guinevere [message #30965] Mon, 14 March 2005 16:08 Go to next message
Hopefully this shot of the Guinevere breadboard will be visible.
The suspense is killing me! [message #30966 is a reply to message #30965] Mon, 14 March 2005 17:52 Go to previous messageGo to next message
none of the pic links work at this time now. now that the easy part is done( building her ) we can deal with the truly mystical and difficult....posting the pics.
regards,
Douglas
Re: The suspense is killing me! [message #30967 is a reply to message #30966] Mon, 14 March 2005 18:03 Go to previous messageGo to next message
boy; you ain't kiddin'. I think I'll learn some foriegn language; it'll be easier than this link stuff.
Say; where have you been anyway?
ummmm.... [message #30968 is a reply to message #30967] Mon, 14 March 2005 19:07 Go to previous messageGo to next message
I have been doing spring cleaning. I discovered there is a cement floor in my garage. For a while there I wasn't sure...Pick up a dead ___, what is useful inside? take out the good bits and make a pile with the rest, package and sort the good bits. Learn to do it faster. EX: removing 2W Allen Bradley pots from Tektronics plug-in modules. And the ceramic terminal strips, and the____, no the 'keep pile' is getting far to big and difuse...re-sort! more crap to the scrap pile.
Also working out the details of the amp's schematic and parts list. I find that there is a whole bunch of stuff that is one detail on top of another. Detail trouble-shooting voltages. Grounding scheme, how big does it have to be? TX orientation...bias, power, inductor, grid choke, OPTx. How to keep all that stuff from interfering with each other.
regards,
Douglas
Re: ummmm.... [message #30969 is a reply to message #30968] Mon, 14 March 2005 20:01 Go to previous messageGo to next message
Yeah I noticed you were scarce this week on the net. I'm Installing a pedestle sink and re-doing the wainscotting in the bath, while tracking down small case of hum. Damned house gets in the way of all this enjoyment.
Glad to see you are interested in the breadboard pics; I will get them up tommorrow if it kills me.
if it kills you... [message #30970 is a reply to message #30969] Mon, 14 March 2005 20:12 Go to previous messageGo to next message
please leave me Guinevere!
regards,
Douglas
Re: if it kills you... [message #30975 is a reply to message #30970] Tue, 15 March 2005 09:05 Go to previous messageGo to next message
No way; if I die I am taking it with me!
Re: Pics of Guinevere [message #30989 is a reply to message #30965] Wed, 16 March 2005 08:53 Go to previous messageGo to next message
Dude, where are the pictures?
I finally got all the noise out of the pre. Sounds very nice. I found out I had a grounding issue with the PARASex amp that was causing a problem. Also, a brand new cable set has a loose connector. If it's not one thing it's another.
Thanks again for the horn site (http://members.aol.com/araiyuichi/). You said you knew somebody that built them. Think you can hook me up with him?.....Colin
Re: Pics of Guinevere [message #30990 is a reply to message #30989] Wed, 16 March 2005 10:19 Go to previous message
They're coming, what a pain figuring this out, it was easier building Guinevere.
Previous Topic: Amp Studies
Next Topic: throw another preamp on the fire, boys!
Current Time: Mon Nov 16 09:57:15 CST 2026
