Home » Audio » Group Build » More amp design considerations
Re: mmmmmm.... [message #30810 is a reply to message #30809] Fri, 04 March 2005 05:57 Go to previous messageGo to next message
Time always moves faster as you get older...that and I am going to have to start working full time for somebody at some point...
regards,
Douglas
Re: mmmmmm.... [message #30811 is a reply to message #30810] Fri, 04 March 2005 06:43 Go to previous messageGo to next message
I am older than you and so will use that seniority to offer this word of wisdom. Time moves the same. So take your time because believe me; you will turn around and wonder where it went. Hurry up and die; thats what me old mum used to say when she saw someone rushing around.
Sorry to hear you must become gainfully employed; this is too much fun.
Input stage [message #30822 is a reply to message #30801] Fri, 04 March 2005 13:33 Go to previous messageGo to next message
cheetah is currently offline  cheetah
Douglas,
Have you considered using a pentode diff amp on the input, instead of a cascode diff amp. Pleanty of gain, good drive capability, much less complexity compared to the cascode.
Joe
Re: Input stage [message #30825 is a reply to message #30822] Fri, 04 March 2005 13:41 Go to previous messageGo to next message
Hey-Hey!!!,
Yes I have. Built with 6AK5, 6AU6, 12BY7, 12GN7, 6AH6, 8136. Missed a few, but the slightly more complex looking cascode works better. Tread Ec2 like the pentode's g2, and you're off.
the g2 being in parallel with the plate does funny thigs( I think ) to the constant current out of the cathode circuit. The cascode is a series afair, and the pentode is a parallel. You still need a good g2 supply...
regards,
Douglas
Re: Input stage [message #30827 is a reply to message #30825] Fri, 04 March 2005 13:46 Go to previous messageGo to next message
So cascoded 5687's e-linear connected to the outout stage sounds like a winner.
By the way, what kind of input/driver stages are you planning to drive a brute like the 813?
Joe
Re: Input stage [message #30831 is a reply to message #30827] Fri, 04 March 2005 19:19 Go to previous message
Hey-Hey!!!,
there is no big deal with a pentode rigged 813. g1-everything else is not too bad, less than 30 pF. A 2A3 grid has more than 60 pF. Not too bad a drive proposition when you get right down to it.
A 6SN7 would be enough...but for appearances sake, a proper DH transmitting valve ought to be used. There are a few cool ones, some with tantalum plates which glow a dull orange. Thoriated tungsten filaments. Must have its appearance done correctly. 866's in the PS of course. Two pairs of 'em most likely, or perhaps 866's and 816's.
regards,
Douglas
Previous Topic: Filament Caps
Next Topic: Fil PS ?
Current Time: Mon May 06 20:12:43 CDT 2024
