Home » Audio » Group Build » Heyboer Tx order - I got 4!?!?
Heyboer Tx order - I got 4!?!? [message #30449] Fri, 11 February 2005 11:30 Go to next message
I got 4 HTS-8074's on my doorstep today. Did everybody else get theirs or did I get all four?.....Colin
Re: Heyboer Tx order - I got 4!?!? [message #30450 is a reply to message #30449] Fri, 11 February 2005 11:39 Go to previous messageGo to next message
Nothing here; they got confused somehow or other.
I'll keep them until Tuesday [message #30452 is a reply to message #30450] Fri, 11 February 2005 11:44 Go to previous messageGo to next message
If I got all 4, then that's not a problem. I'll just send them out to you guys. I'll give it a couple of days to get sorted out.
Now if FedEx could just find my house, I'd be happy. My order from Angela has been in Cincinnati for a couple of days riding around on a truck......Colin
Re: I'll keep them until Tuesday [message #30454 is a reply to message #30452] Fri, 11 February 2005 12:24 Go to previous messageGo to next message
HEy-Hey!!!,
How do they look? what do they weigh? are you happy with them?
regards,
Douglas
Pretty happy and questions [message #30456 is a reply to message #30454] Fri, 11 February 2005 12:50 Go to previous messageGo to next message
They look very nice. Very professional job.
They weigh about 5-6 pounds per. I was a bit freaked out when I picked up the box, since I was only expecting one.
Yes, I am happy with them.
Questions:
1) Is it possible to use these in our amp build. I really hate to send the extras back if we're going to use them later on. Can you design an amp around these? If so, I'll keep them. I know Heyboer is a small company and I really hate to see them eat the cost. They were doing us a favor in the first place.
2) There are lost of pretty wires hanging out of the Tx. Is there a conventional color scheme for the secondaries?
......Colin
Re: Heyboer Tx order - I got 4!?!? [message #30458 is a reply to message #30449] Fri, 11 February 2005 13:29 Go to previous messageGo to next message
HI Kids,
I got mine today, just one.It's very nice, about 6-7lb, Plenty big enought to run 1 or 2 ity bity tubes.
I do think they would be large enough to run a pair of amps, there rated for at least 100ma.
As for the secondarys
Yellow 5V, green 6.3V
AT 122VAC (black)
Red/yellow= CT, Blue/red 262VAC, Blue 340VAC, Red 422VAC.
...John
Re: Pretty happy and questions [message #30461 is a reply to message #30456] Fri, 11 February 2005 13:45 Go to previous messageGo to next message
I hope that`s possible - various taps and 100mA capacity can be good for mono 2A3 SE amp with B+ of about 305V/70-80mA (LCLC probably). I started working on the prototype, but I`m slow and don`t have too much time (work...), but one of these years I`ll post the full "story" with pictures in color, step-by-step instructions, etc...
Stay tuned
Green = 6.3V?? [message #30463 is a reply to message #30458] Fri, 11 February 2005 13:54 Go to previous messageGo to next message
I thought we got a 12.6V secondary.?????......Colin
Re: Green = 6.3V?? [message #30465 is a reply to message #30463] Fri, 11 February 2005 14:17 Go to previous messageGo to next message
No it' 6.3VAC CT. Remember It is designed as a rectifer winding.
We can run the 12V sig tubes off it but the plan was to use a separate filament supply...John
Re: Pretty happy and questions [message #30469 is a reply to message #30456] Fri, 11 February 2005 14:29 Go to previous messageGo to previous message
Well, you can sort them with an Ohm-meter.
400-325-250-0-250-325-400 will all have continuity. that's 7 of the many.
The 5 and 6.3 are going to be near 0 Ohms( and I think youse got them center tapped, so the remaining pair of three wires with common continuity will be the filament windings). If I remember correctly, and the filament windings are CT, then the only single pair continuity will be the line/input.
Apply votlage to this one slowly with a pigtail and a Variac and confirm voltages with a *FEW* VAC input at first. You don't want to try putting 120V on a 5V winding...
Make a drawing and record your measurements. Don't loose the drawing!
regards,
Douglas
Previous Topic: So; where were we?
Next Topic: Rev. 6 update
Current Time: Thu Apr 18 13:15:25 CDT 2024
