Home » Audio » Group Build » LED values?
LED values? [message #30349] Tue, 01 February 2005 20:35 Go to next message
I remember somewhere that the LEDs are supposed to be around 20mA apiece. I do not remember if there is was a specified voltage. Can anyone refresh my memory?
Re: LED values? [message #30350 is a reply to message #30349] Wed, 02 February 2005 03:33 Go to previous messageGo to next message
Light-emitting diodes are like other diodes, in that they are formed by a semiconductor PN junction. The semiconductor material of the junction is what sets the voltage required to forward-bias it. For example, germanium diodes are forward biased at 0.3v and silicon diodes at 0.7v. That's what sets the operating voltage of a silicon of germanuium transistor too.
Light-emitting diodes use different semicondutor junctions to provide different colors, and each has a different forward-voltage requirement, usually between 1 and 4 volts. The typical red LED requires about 1.7 volts. Semiconductor junctions that provide higher frequency colors require higher forward voltage bias.
Red lead [message #30351 is a reply to message #30350] Wed, 02 February 2005 05:55 Go to previous messageGo to next message
Hey-Hey!!!,
The red seem to be the quietest. It could be done with a 4V single, perhpas green or blue, but I have found even orange ones to contribute some noise. Perhaps it was just the Radio-Shack ones I tried, but...
The 20 mA red, standard red, are the ones you want. The internal resistance of the specialty red ones is not optimum for Audio use.
regards,
Douglas
Re: Red lead [message #30355 is a reply to message #30351] Wed, 02 February 2005 07:02 Go to previous messageGo to next message
Those little LEDs always make me think of fireflys.
What about using a string of regular silicon diodes? I've used them to bias circuits a lot, but the first time I saw an LED used for this was in the CCS on Bottlehead stuff. You get higher forward-bias voltage with an LED than a regular solid state diode but you can sure use a series string instead. I always thought the LEDs were used for effect as much as anything else.
interesting... [message #30358 is a reply to message #30355] Wed, 02 February 2005 07:42 Go to previous messageGo to next message
I have a feeling that a small string of Schottky would be a cool idea. Forward biased at ~.4V each. We'd need more than two, but it would offer a far finer adjustment of the bias voltage.
I suspect that the Schotky would be quieterin fwd bias than a Si one would be. Nice suggestion I must say. If I didn't need a 20-30 of them in the new one ( instead of 6 red LED's ), I'e be solderig up a string.
regards,
Douglas
Re: interesting... [message #30359 is a reply to message #30358] Wed, 02 February 2005 08:33 Go to previous messageGo to next message
Schottky diodes might be attractive. But the problem is that the voltage across them is much lower, so you'd need even more of them.
Re: LED values? [message #30363 is a reply to message #30349] Wed, 02 February 2005 13:34 Go to previous messageGo to next message
cheetah is currently offline  cheetah
For the adventurous, a 6BE3 TV damping diode @ 15mA current should give approx 3-3.5 V bias voltage.
Saw this done this way on the Axiom Amp. Haven't tried it, but it sure looks interesting.
Joe
Re: LED values? [message #30371 is a reply to message #30350] Wed, 02 February 2005 16:13 Go to previous message
The red LED at RS were rated between 2.1 and 2.3V, and ranged anywhere from 15 to 60mA current draw....Colin
Previous Topic: Presenting....
Next Topic: Heater PS schematic
Current Time: Mon Oct 19 01:03:46 CDT 2026
