Home » Audio » Group Build » DN2540
DN2540 [message #30201] Fri, 21 January 2005 16:16 Go to next message
Digikey has these at $0.66 if we buy enough for all (20 parts.) Would you guys like me go ahead and order. I can also get the LED's at the same time. Maybe I'll have $20 (min. order w/ no surcharge) when all totaled.....Colin
Re: DN2540 [message #30202 is a reply to message #30201] Fri, 21 January 2005 16:27 Go to previous messageGo to next message
If you are generously offering to do so I for one would be very gratefull. Have you factored in the shipping to each one of us. If that is acceptable then put me down and let me know what the final amount is including the shielded wire. Thanks and please allow for something for me to do also, whatever needs doing that you can think of. J.R.
Re: DN2540 [message #30204 is a reply to message #30202] Fri, 21 January 2005 16:37 Go to previous messageGo to next message
Don't worry about the cost. A VERY small price to pay for the friendship.....Colin
DN2540****N5! make sure you understand this! [message #30205 is a reply to message #30204] Fri, 21 January 2005 16:47 Go to previous messageGo to next message
just make sure it is the N5, TO-220 version. The TO-92 won't stand the heat. However, since the N5 is only needed for the 'top' MOSFET, you can split between the N3 for the 'bottom' of the cascode, and use the heatsinked( and more expensive ) N5 on 'top'.
As I could use some of the N3's ( and Mouser stopped stocking them ), thanks for the notice on that source. If they are seling the N5 for 66-cents, I will buy a *BIG* sack of them....
regards,
Douglas
Dooohhh [message #30206 is a reply to message #30205] Fri, 21 January 2005 17:06 Go to previous messageGo to next message
Digikey's part number DN2540 was a small inductor for $0.66. My bad.
However, Mouser does carry the DN2540 (Supertex MOSFETs - Depletion Mode N-Channel TO-220 400V 25Ohm) at $1.83 (
Re: Dooohhh [message #30207 is a reply to message #30206] Fri, 21 January 2005 17:24 Go to previous messageGo to next message
The mouser PN is the one. They may require a 50 piece order. If so, count me in for a few...
regards,
Douglas
Re: Dooohhh [message #30209 is a reply to message #30207] Fri, 21 January 2005 20:01 Go to previous messageGo to next message
Here Here; if thats what it takes; 50 piece we have you covered, just let me know; and Colin; appreciate the vote of confidence.
I'll order 20 pcs. tomorrow [message #30213 is a reply to message #30202] Sat, 22 January 2005 10:01 Go to previous messageGo to next message
I'll place an order for 20 DN2540 tomorrow. This should be enough for 5 preamps (4 per pre). When I get them in I'll send to each member by ground mail. Please email (colinhester(at)yahoo.com) me your real name and mailing address.....Colin
Re: I'll order 20 pcs. tomorrow [message #30214 is a reply to message #30213] Sat, 22 January 2005 12:46 Go to previous messageGo to next message
You're the best, Colin. Let me know the amount so I can send a check.
Re: I'll order 20 pcs. tomorrow [message #30215 is a reply to message #30214] Sat, 22 January 2005 12:50 Go to previous messageGo to previous message
The price for 4 is about the same as a couple of beers. When we finally meet, you owe me.....Colin
Previous Topic: My idea...
Next Topic: Resistor wattage specs?
Current Time: Wed Apr 24 13:16:42 CDT 2024
