Home » Audio » Craftsmen » Clear coat tip
Clear coat tip [message #29829] Thu, 09 November 2006 16:55 Go to next message
Burl is currently offline  Burl
After using your stain/oil, and then your clearcoat, if you're like me its hard to keep out the fine bits of dust that ruin that glass-like finish. If you know someone who does auto painting, use a foam buffing pad with a low speed buffer and fine grit buffing compound to take out the dust nibs and make it shine. Just make sure the clearcoat has hardened about a week.
Re: Clear coat tip [message #29835 is a reply to message #29829] Wed, 15 November 2006 11:59 Go to previous message
Good tips. I'll add one.. on small pieces, it can help to spray them with a furnace filter under them (raise the piece up a bit first). This seems to do a good job of keeping spray and dust from bouncing back onto the project. A clean filter, of course.
Previous Topic: Guess I'll have to build another base for the amp
Next Topic: Mahogany Chassis for DIY Dac. Thanks Bill
Current Time: Fri Apr 26 00:13:31 CDT 2024
